Single Number Reach stopping first phone
kevinwincott
I have just configured Single Number Reach for a user on out UCM520 but when the call rings to the second device (mobile phone) the Cisco IP Phone continues to ring, is there a way of disabling this feature? What im looking to achieve is a user calls the IP Phone, theres no answer so the call goes on to the mobile phone.
Jaime Valencia
That's the way SNR works, the IP Phone and the remote destination ring at the same time, for what you want, just configure CFNA/CFB and that's it.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
