Single Sign-on for Unity Connection, Commuications Manager 9.x
jforcum
When I read single sign-on requirements for Unity Connection v9.x and Communications Manager 9.x, it appears that Cisco is mandating an SSO integration only with OpenAM. What about Cisco support for some of the other 50+ AD Manager applications out there?
Does anyone have CUC or CUCM (ver 9.x) experience for SSO integrations using something other than ForgeRock's OpenAM?
I thinking Cisco should provide direction for SSO integration for any SAML 2.0 compliant AD manager.
skilambi
This issue has been brought up here too. This does need partner access. You may also want to post this on the partner side versus the public side
View the full discussion
Srini
