SIP trunk configuration on both CUBE and CUCM not working
niceinfotech
Frequent Visitor
Frequent Visitor
I’m relatively new to Cisco technologies and have been working on configuring SIP trunking between a CUBE (Cisco Unified Border Element) and CUCM (Cisco Unified Communications Manager) and also between a CUBE (Cisco Unified Border Element) and the Service Provider . I followed the Cisco white papers and documentation to set up the configuration, but I’m facing an issue where:
  1. Outbound calls from internal extensions are not going out.
  2. Inbound calls from outside cannot reach our internal extensions.
 I have already gathered and uploaded the following:
  • Topology diagram
  • Configuration files (CUBE and CUCM)
  • Logs (CUCM and CUBE)
  • Screenshots of the CUCM configuration
Here’s a brief overview of my setup:
  • CUBE Version: Cisco IOS XE Software, Version 17.03.04a
    Cisco IOS Software [Amsterdam], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 17.3.4a, RELEASE SOFTWARE (fc3)
  • CUCM Version: System version: 14.0.1.10000-20
  • SIP Provider: BSNL
I’ve double-checked the configuration against the Cisco documentation, but I’m clearly missing something. Could someone please review my configuration and logs to help identify the issue?
Marco Rojas Abarca
Dear niceinfotech,
According to the debugs uploaded on the file, seems to me like the router is unable to match a dial-peer as outgoing for this call:
*Feb 3 12:00:40.884: //-1/52C7F6E580BA/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=918837099070
----- ccCallInfo IE subfields -----
cisco-ani=918837099070
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=+913642310489
*Feb 3 12:00:40.890: //179/52C7F6E580BA/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 404 Not Found
Via: SIP/2.0/UDP 10.181.34.1:5060;branch=z9hG4bKcczpl12uk912km1411ccur5upT09274
From: <sip:918837099070@siptrunk.ims.bsnl.in;user=phone>;tag=sbc08038nh1nhyy
To: <sip:+913642310489@siptrunk.ims.bsnl.in;user=phone>;tag=AA3364-C0C
Date: Mon, 03 Feb 2025 12:00:40 GMT
Call-ID: asbcyuy89ubhb9z8y1gy8unzf9dzu2a82u2f@10.191.102.18
CSeq: 1 INVITE
Allow-Events: telephone-event
Warning: 399 172.21.6.185 "No matching outgoing dial-peer"
Server: Cisco-SIPGateway/IOS-17.3.4a
Reason: Q.850;cause=1
Session-ID: 3c8e7ba153ab57d7893cbfa7d121572f;remote=2aca406198cc5d12b039ee35263ae028
Content-Length: 0
Kindly find below a couple of very useful references which you can use to diagnose your issue further:
Understand Matching Inbound/Outbound Dial Peers on IOS Platforms
https://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/14074-in-dial-peer-match.html
Determine Voice Translation Rules
https://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/61083-voice-transla-rules.html
Hope this information helps,
Sincerely,
Marco R.
As @Marco Rojas Abarca pointed out, the call is failing with No matching outgoing dial peer. The reason is that the SIP INVITE is coming in with a dialed number of +913642310489 where your router's dialplan does not have the + configured. This is also why the incoming dialpeer for the call is dial-peer 10 in lieu of a specific match.
I would suggest reconfiguring your dial-peers to be specific about capturing calls inbound to the CUBE with 'incoming called-number' patterns.
As for dealing with the +, you would either need to add (or reconfigure) dial-peers or add voice translations to remove the +.
Maren
