Solution to avoid mobile roaming costs
6rlopez_2
Is there any solution/product that allows to reduce or eliminate the cost of a call from a mobile device in travel outside its country?
Is it possible to get this with Cisco Unified Mobile?
I know you can eliminate the roaming cost if the mobile is on its country and makes an international call. But, what happens if the mobile is in another country?
will.alvord
Level 5
Level 5
Just a thought, but what about a sip client on a smartphone using either wifi or a cheap sim card for data?  Newer android devices (can't speak for the iphones) have a native sip client anyways.  You'll probably see some latency related voice quality issues, but that's essentially free + the cost of the sim card assuming your device has a sim card.  I guess the missing relevant factors are how much time talk time is expected, level of acceptable voice quality, and type of mobile device.
