Speed Dial management on UC expansion modules
MinyuVV_14
Hello, guys!
As you all know, providing management and provision for speed dials and BLFs on UC phones with expansion modules (like 7915/7916) is a huge pain in the ass, if we talk about enterprise environment. Sure, such great instrument as Bulk Administration Tool helps a bit, but i'm curious, if there exists other software products(like third-party) or instruments, which can provide usable and robust management/monitoring for speed dial buttons?
Or, if you can, please share your experience or thoughts in dealing with speed dial management.
Aaron Harrison
Putting this sort of application together isn't so hard, especially for something fairly simple like this.
What would you want it to do exactly? If you could have your 'ideal' piece of software?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hi, Aaron
The main goal of this "ideal tool" is, i assume, to perform monitoring for speed dials on phones and check, if there is a particular DN to a corresponding SD. This kind of monitoring will eliminate situation, when DN was deleted, but SD, which points to this DN, is still persist on some phone.
Alexander
