SQL CDR reporting in CUCM ver 8
GarageLand42
I was able to run this SQL statement in ver 7, but it does not work in version 8
run sql select * from car:tbl_billing_data where originalcalledpartynumber like '%2966'
  in CUCM ver 8, I recieve the following error
"Database not found or no system permissions"
Jaime Valencia
The syntax for the qry has changed, it must look like this:
run sql car select * from tbl_billing_data where originalcalledpartynumber like '%2966'
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
Awesome,  that worked.
