SQL warning
jeff.singh_2
Level 3
Level 3
we have Unity404 Sr1, with failover UM, e2k3. We continously get the following msg in app log every 10 minutes:
Event Type: Warning
Event Source: CiscoUnity_NodeMgr
Event Category: Run
Event ID: 1033
Date: 8/19/2005
Time: 12:10:22 PM
User: N/A
Computer: UnityVM1
Description:
AvCsNodeMgr unable to connect to SQL Server on LocalHost. Error 0x80040000.
This appears on the primary server. Replication is working as I have tested this by adding text files in \commserver stream files folder and this gets replicated. Failover also works ok. Name resolution also working ok.
Have also done this :
Open SQL Enterprise manager, SQL Server Group.
Right click on the Server Group, select New SQL
Server Registration, and select the secondary unity server
Any advice appreciated.
7 Replies 7
jeff.singh_2
Level 3
Level 3
Hi, can anybody help with this ?
Hin Lee
Open SQL Enterprise manager\SQL Server Group
Right-click on the Server Group, select New SQL Server Registration and selected the secondary unity server
Please let use know if you get any error messages and post them here (don't forget to check the app logs)
I suspect that you might get "Cannot generate SSPI context" and maybe a failed sql server registration.
Hi Hin,
I have tried this as I saw one of your previous threads and the secondary server registration worked ok with no reported errors.
Any other suggestions.
I am still leaning towards spn.
From the command prompt do,
setspn -l primary-unity
setspn -l secondary-unity
Compare the output of both and let us know if there is a difference.
Incidentally, what account is used to start the AvCsNodeMgr service on both servers? What is used to start the MsSqlServer and SqlServerAgent service?
(Sorry I missed the initial troubleshooting that you had registered the 2nd server on Sql Ent. Mgr.)
Hi Hin,
what do these commands actually test, they won't affect the system in anyway will they as the system in now in production. Also do we run both on the same server or on primary and then secondary?
thanks
J
Found following bug:
CSCec80854
No fix at present, cosmetic only.
Hi Hinho
Came across this thread. I had the following error message when trying to register primary sql server on 2nd server's SQL enterprise manager or try to re-run the failover wizard on 2nd server.
[0x80040000] : [Microsoft][ODBC SQL Server Driver]Cannot generate SSPI context
The setspn output for the two servers are:
unity01 primary server
C:\Program Files\Resource Kit>setspn -L unity01
Registered ServicePrincipalNames for CN=UNITY01,OU=RMY,DC=region,DC=ca:
MSSQLSvc/unity01.region.ca:1433
SMTPSVC/UNITY01
SMTPSVC/unity01.region.ca
HOST/UNITY01
HOST/unity01.region.ca
ykr-unity01-fai failover server
C:\Program Files\Resource Kit>setspn.exe -L unity01-fai
Registered ServicePrincipalNames for CN=UNITY01-FAI,OU=RMY,DC=region,DC=ca:
HOST/UNITY01-FAI
HOST/unity01-fai.region.ca
Somebody suggested deleting the MSSQLSvc/unity01.region.ca:1433
SMTPSVC/UNITY01
on the primary server. I am wondering what will happen if remove it?Will it stop the sql and smtp service on the primary server? Why this will help? Thanks
