SSO using SAML support for CMS
Bgeorge1
Any idea whether the Cisco Meeting Server CMS currently support SSO using SAML? If not, is this feature in the road map for next year?
Jaime Valencia
I haven't seen anything in the docs about SSO and CMS, roadmap questions are NDA material and cannot be discussed at a public forum, you'd need to reach out to your SE, or post in the partner community (if you're a partner)
java
if this helps, please rate
Jaime Valencia
java
turkovAndrey
It works since CMS 3.1 but in very strange way. You still have to enter your login even if you are domain user on domain PC and then push the button SIGN IN. I don't understand why it doesn't work the same way as SSO for CUCM.
