Steps to Configure Speed Dial
abhishekbanik
Need steps to configure speed dial.
Abhishek
RohiniKCW
Go to the phone / UDP configuration page and check the Phone Button Template and check whether you have enough lines available to configure as speed dials. If not create a new Phone button template with sufficient speed dial lines and assosiate the newlt created Phone Button Template to your phone /  UDP configuration page. Clikc the link Add/Update Speed Dials on the same page and update the speed dial with the requested entries with the Label asthe Speed dial Label and the Number as the number where the speed dial shld reach.
The UDP profiles has to log out and login back for the changes to take effect.
Hope this helps..
Please let me know whether this was infromative or not.
Marcel Ammann
Level 3
Level 3
CUCM:
1. Create a phone button template with speed dials and add this to the phone(s)
CUCME:
ephone  1
  speed-dial 1 00006666 label "The Name"
Kind regards,
Marcel Ammann
