SX20 extra camera connection
Hi All,
One of our customer as a requirement of Sx20 with extra camera.
I have proposed for the SX20 with 12X but I am doubt with, sx20 extra camera can we connect it or not in C series it was there option of two camera connectivity.
Please help on the SX20 12X extra camera and connectivity does it work or not.
If it works please share a part code of Camera which support.
And the cables which are required for the camera to connect with SX20.
If possible kindly share a cables requirement part code.
Laxminarayan
vivekksi
Hi Laxminarayan,
I am not very clear what do you mean by extra camera, since SX20 is not integrated device, it has limitation of how many input device can be connected.
As per install guide and port availability you can connect only single camera due to single HDMI-in
Connect your camera (option A, B or C) to the codec
Camera option A: PrecisionHD1080p12X
Camera option B: PrecisionHD1080p4XS2
Camera option C: PrecisionHD1080p2.5X
Install guide for reference: http://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/quick-set-sx20/installation_guide/sx20_quick_set_installation_sheet_for_web.pdf
Vivek
vivekksi
Hi Laxminarayan,
Vivek
Hi Vivek,
Thanks for the reply and shared documents i got it.
Laxminarayan
Please mark this as answered so that people shouldn't comment any further.
Vivek
Hi Laxmi,
you can also refer the link for details
http://www.cisco.com/c/dam/en/us/solutions/collateral/business-video/business-video/endpoint-product-matrix.pdf
regds,
aman
