You will need to troubleshoot this by setting the Sync Agent logs to debug level. Then try to start the Sync Agent manually and collect the traces.
Generally this issue requires you to do the following:
- Delete the CUP node Entry from CUCM Server page
- Add the IMP server entry again to the CUCM Server page
- Re-install CUP Node
Manish
