test - validate_network : Default gateway failed
Rosa Ladera
Hi.
I got Default gateway failed running utis diagnostic test on
Welcome to the Platform Command Line Interface
VMware Installation:
2 vCPU: Intel(R) Xeon(R) Gold 5120 CPU @ 2.20GHz
Disk 1: 80GB, Partitions aligned
6144 Mbytes RAM
admin:show version active
Active Master Version: 11.5.1.12900-21 Unrestricted
Active Version Installed Software Options:
cmterm-6901-sccp.9-3-1-SR2-2.cop
ciscocm.version3-keys.cop
cmterm-7970_7971-sccp.9-4-2SR3-1.k3.cop
ciscocm.migrate-export-v1.18.cop
cmterm-7975-sccp.9-4-2SR3-1.k3.cop
cmterm-7941_7961-sccp.9-4-2SR3-1.k3.cop
ciscocm.11_5_struts_2_3_32_upgrade_v2.cop
cmterm-69xx-SCCP.9-4-1-3SR3.k3.cop
cmterm-7942_7962-sccp.9-4-2SR3-1.k3.cop
cm-locale-pt_BR-11.5.1.3000-1.cop
ciscocm.ucmap_platformconfig.cop
cmterm-6911-sccp.9-3-1-SR2-3.cop
ciscocm.dst-updater.2018c-el6-00.11.5.1.cop
admin:show hardware
HW Platform : VMware Virtual Machine
Processors : 2
Type : Intel(R) Xeon(R) Gold 5120 CPU @ 2.20GHz
CPU Speed : 2200
Memory : 6144 MBytes
Object ID : 1.3.6.1.4.1.9.1.1348
OS Version : UCOS 6.0.0.0-2.i386
Serial Number : VMware-56 4d fc b5 74 a7 96 82-5a b6 d5 9a d6 e7 20 53
RAID Version :
No RAID controller information is available
BIOS Information :
PhoenixTechnologiesLTD 6.00 12/12/2018
RAID Details :
No RAID information is available
Physical device information
Number of Disks : 1
Hard Disk #1
Size (in GB) : 80
Partition Details :
Disk /dev/sda: 10443 cylinders, 255 heads, 63 sectors/track
Units = sectors of 512 bytes, counting from 0
Device Boot Start End #sectors Id System
/dev/sda1 * 2048 29028351 29026304 83 Linux
/dev/sda2 29028352 58054655 29026304 83 Linux
/dev/sda3 58054656 58578943 524288 83 Linux
/dev/sda4 58578944 167772159 109193216 5 Extended
/dev/sda5 58580992 66772991 8192000 82 Linux swap / Solaris
/dev/sda6 66775040 167772159 100997120 83 Linux
admin:
sudaggar
try to ping default GATEWAY=147.65.21.250, if its reachable.
looks like default gateway unreachable.
