ā08-06-2012 01:35 PM - edited ā03-19-2019 05:20 AM
I have a main site with 10 SIP trunks. I am trying to have long distance calls from the remote site to go across the VPN and call out the SIP trunks at the main site. I started by just running a simple test to call a 7 digit phone number from the remote site through the main site. Here is my configuration with example phone number:
Remote site: (192.168.11.1)
dial-peer voice 2101 voip
destination-pattern 95551234
preference 1
session target ipv4:192.168.10.1
voice-class h323 1
dtmf-relay h245-alphanumeric
no vad
Local Site: (192.168.10.1)
incoming called-number 95551234
voice-class h323 1
fax protocol cisco
no vad
dial-peer voice 1030 voip
description **CCA*North American-7-Digit*7-Digit Local**
translation-profile outgoing PSTN_Outgoing
preference 1
destination-pattern 9[2-9]......
session protocol sipv2
session target sip-server
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
voice translation-profile PSTN_Outgoing
translate calling 1111
translate called 1112
translate redirect-target 410
translate redirect-called 410
voice translation-rule 410
rule 1 /^9\(.......)\)$/ /970\1/
rule 2 /^9\(.*\)/ /\1/
rule 15 /^...$/ /9702430727/
voice translation-rule 1111
voice translation-rule 1112
rule 1 /^9/ //
When I call from the remote site, the called phone rings, but there is no one there. The remote caller hears a fast busy. Any help would be appreciated!
Thank You.
ā08-06-2012 02:16 PM
Post "debug ccsip messages" and provide called and calling number.
Is there a reason you have H323 between the sites and SIP to SIP trunk, why not configure SIP between sites as well?
Can do you hard code everything to one codec? As your outbour leg from remote site has no codec class or codec specified which means it will default to G729, yet your SIP trunk dial peer has codec class (which you did not post).
You mention VPN connection, Is there any NATing taking place? Are all needed ports permitted?
HTH,
Chris
