06-03-2013 11:00 PM - edited 03-19-2019 06:48 AM
Hi All,
Please clarify this question , Translation pattern will affect outgoing calls?, I have configured the below
Translation pattern XXXXXX
Partion <none>
description preserve 6 digit number in Special PT
numbering plan <none>
route filter <none>
MLPP Precedence Default
Resources Priority namespace network domain <none>
Calling search space Italy-00-fax-css
Route option * route this pattern
after configuration some user reported not able to dialout particular series number ..like land line.
I could not find on VG debug commands. finally I removed the TP from CUCM.
Thanks in advance
Siva
06-03-2013 11:20 PM
Yes. If it is in the None partition, it is visible to all phones. Try moving this TP to a partition, add that partition to certain Calling Search Spaces.
G.
Sent from Cisco Technical Support Android App
07-10-2013 02:11 AM
Thnak you Gergely , sorry for the delay reply
