Tranlation pattern will affect outgoing calls?
sivashanmugam g
Hi All,
Please clarify this question , Translation pattern will affect outgoing calls?, I have configured the below
Translation pattern XXXXXX
Partion <none>
description preserve 6 digit number in Special PT
numbering plan <none>
route filter <none>
MLPP Precedence Default
Resources Priority namespace network domain <none>
Calling search space Italy-00-fax-css
Route option * route this pattern
after configuration some user reported not able to dialout particular series number ..like land line.
I could not find on VG debug commands. finally I removed the TP from CUCM.
  1. Translation pattern will affect outgoing calls?,
  2. How to trace this kind of issue.
Thanks in advance
Siva
Gergely Szabo
Yes. If it is in the None partition, it is visible to all phones. Try moving this TP to a partition, add that partition to certain Calling Search Spaces.
G.
Sent from Cisco Technical Support Android App
Thnak you Gergely , sorry for the delay reply
