Transfering call directly to VoiceMail, 3 methods
Randall White
Level 3
Level 3
Hi All,
I can't find a link on the CCO anymore. It discussed 3 different ways to transfer calls directly to voicemail. I'm not talking about the one for CCM 3.3.2spD, that's been discussed on recent threads.
The link I'm talking about used newer versions of CCM and Unity. I was using this a few months ago, but I lost the bookmark!
Thanks, Randy
actually, you'll find all the tech tips for all topics under the general tech tip link at the bottom:
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps2237/prod_tech_notes_list.html
there's 4 or 5 tech tips about transfering directly to a mailbox in here, one of them is probably the one you're looking for.
lindborg
All the documentation can be found on the newly reorganized docs page here:
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps2237/tsd_products_support_series_home.html
the transfer directly to voice mail tech tips can be found under the "configuration example and tech tips" link I believe.
