10-21-2014 03:51 AM - edited 03-19-2019 08:45 AM
I am trying to allow users do dial fan extension from the opening greeting with unity connection 7
It works for some extension numbers but for others the call is routed straight to the Voice mail of the number that was dialled
Any thoughts
10-21-2014 05:25 AM
Hi.
You need to create a dedicated Call handler on UC and a CTI Route point with the same number of configured destination on Call handler.
On DN configuration, select Forward All on Directory Number on CTI RP configuration.
Carlo
10-21-2014 07:36 AM
Adjust the transfer settings PER user as required to either reach VM, or ring their phone.
10-21-2014 08:59 AM
Sorry
what I should have said was when a caller hits the opening greeting and get the prompt "you may dial an extension at any time" they can only dial certain users extensions.
ie 4 digit extension beginning with a 6 is ok but 5 digit beginning with a 4 is not.
I have checked the restriction tables and also set them to allow everything but it makes no difference.
Thanks.
What traces would I see this on ?
10-21-2014 09:09 AM
Hi.
To see the call behaviour can download remote port status monitor a useful tool from ciscounitytools.com
Regards.
Carlo
10-22-2014 01:37 AM
i have used the port monitor tool, this just shows the call flow in and out of Unity, what ~I need to be able to see is the decision process Unity goes through when a call "dials an extension" at the opening greeting.
In gateway terms this would be analogous to selecting a dial peer based on digits recieve
Thanks.
