Transfert OFFNet to ONNet Call
Junior Mateus
Hi Everybody,
I´m facing to an issue, i´m not  able to transfer, hold or park a Call coming from the Pstn (offnet ) to an internal DN (OnNet) Extension
I Verified the service parameter, the MTP, the Device Pool also the Media Group but everything seem ok
Here is a Doc ,where i have place some specified print screen for give you clear idea.
The Gateway have the same CSS than my inside Phone, mean i´m able to call every phone DN from my Gateway without any Problem
But when i try internally to an Inside DN to an Inside DN, mean ( ONnet to ONet) i can do everything (Park,Hold,transfert)..
Again thank you in Advance!
Anas Abueideh
Level 9
Level 9
what is your call manager version ?
try to restart IP Media stream service
Anas
don't forget to rate the helpful posts
