TRaP - Two Calls every time
orebollido
Unity 4.0(5) on Windows 2003 non-SP1
Exchange 2003 SP3
CallManager 4.0(2a)sr2b
I used the Unity Advanced Settings Tool to change the 'Administration - Set Maximum Number of Rings to Wait for TRAP Calls' from the default of 4 rings to 3.
Now, when VMO calls the phone and you don't pick it up, it will ring 3 times, hang up, then ring again 3 times before it says 'The specified phone does not answer'. Is this normal operation for it to call two times before it gives up?
mrmccann
This is not normal operation, it should only call the phone once. This problem was introduced in Unity 4.0(5). We have a bug open on this - CSCsb65242.
