troubleshooting cupc 8.0 softphone mode ?
runariversen
just installed the cupc 8.0 but cant get the softphone up and registered, it seems like the softphone is disabled in the client.
Anyone have any nkowledge about this and any configuration tip / places to check ?
I have run the troubleshooting tool, and it seems like the cfg file etc is ok, troubleshooter cup is all green etc, and i can log into the cupc klient etc.
thank you,
Runar iversen
jballari
Hi Runar,
Have you configured the CUCM? Sorry if I state the obvious but you do need to configure the CUCM side for CUPC to work as a softphone. Go to the "Device" menu on CUCM, select CUPC as the type and fill in the details for each user.
Here is a link that can help you (although it's based on 6.x version, steps haven't changed very much)
https://supportforums.cisco.com/docs/DOC-1112;jsessionid=0958FBC44DCBCA0879822014F42FB536.node0
Cheers,
Jose
hi,
yes i have configured the cucm but maybe not correct
I was of the understanding that the cupc used the csf and should be configured in the cucm as a csf device and not a cupc for cupc 8.0, could someone clarify ?
thanks,
Runar
As far as I know, you should be able to configure it with CSF but also CUPC device type. Make sure you run compatible versions too: CUPC 8 needs CUPS 8.0.2, which i believe is in beta now. Have a look at the below link on this community for more documentation and support:
https://communities.cisco.com/community/partner/collaboration/uc/beta
Cheers,
Jose
