TTS installation after Unity installed
Is it possible to install TTS option after completly installing the Unity server. I did not have license to TTS during initial install, and did not select the option to install TTS. Now I have the license for TTS and wordering whether I can install TTS with reinstalling the Unity from scratch.
Thank you
kechambe
Level 7
Level 7
You can add it by re-running setup and then selecting TTS during setup.
Keith
Thank you
