Twilio SIP Trunking with CUBE
JOHN PARDUHN
I am working on my lab setup with CUCM 11.5, a 2811 router running IOS 12.4, and a Twilio SIP trunk. I can route a call to the trunk from an IP phone without an issue, but the call won't set up. I get the following dump from the Twilio debugger (redacted):
ParametersShow Raw
From<sip:6305551212@domain_sip.pstn.twilio.com;user=phone>;tag=11296D5C-10CC
To<sip:+14154758378@domain_sip.pstn.twilio.com;user=phone>
SipSrcIp1.2.3.4
SipSrcTransportudp
SipCallId6CBE739-EA5A11E6-99CBC1B4-E343E364@192.168.0.2
UserAgentCisco-SIPGateway/IOS-12.x
Message TextShow Raw
MsgThe body of the request was empty, which is not allowed in this context.
ErrorCode32103
LogLevel
WARN
I'm curious if anyone has worked on this setup and what your experience was. I'd really like to have this proof-of-concept working for my own knowledge. Thanks in advance!
Hello all,
I had the same problem.This is because Twilio doesn't accept SIP delayed offer. In the INVITE message SDP should be included which can be done when you force Early Offer
Twilio-CUBE(config)#voice service voip
Twilio-CUBE(conf-voi-serv)#sip
Twilio-CUBE(conf-serv-sip)#early-offer forced
Theo
keglass
Level 7
Level 7
parduhnj,
I recommend you also post this to the Cisco Support Community for additional feedback from Cisco technical experts and other users.
https://supportforums.cisco.com/
Thank you for participating in the community.
Kelli Glass
Moderator for Cisco Customer Communities
Thanks, Kelli. I will follow your recommendation.
Hello all,
Theo
