04-27-2014 01:40 PM - edited 03-19-2019 08:08 AM
I have setup a HQ and Branch office. HQ is setup as Customer service location and Branch as Sales location. When PSTN calls Customer Service 800 number, the application runs fine. But when PSTN calls Sales 888 number, the call gets disconnected without any busy tone or anything.
I am using G711ulaw within sites and G.729 in between sites. UCCX and call manager servers are located in the HQ.
When running a reactive debug in Sales application, its triggers and stops at "Accept" step.
Any help is greatly appreciated.
thanks
04-28-2014 12:12 AM
Hi.
If the 888 number lands on VG at Branch, and VG at branch uses g729 to HQ, remember that when you call an UCCX application, a CTI port is engaged and it uses G711 (it depends on how you defined it at initial setup).
You can verify the codec used between CUCM and UCCX by opening UCCX admin page and selecting "System" --> "System Parameter"
Carlo
04-28-2014 07:36 AM
Thank you Carlo for the reply. I have G711 as the codec used between CUCM and UCCX. I also configured a transcoder in HQ gateway router and CUCM but that didn't help.
04-28-2014 07:52 AM
Hi.
Where is located the PSTN line where 888 calls come from?
Try to configure a dialpeer in branch VG pointing to CTI ports DNs using g711 codec and send the output of a debug voice ccapi inout.
Carlo
04-29-2014 11:10 AM
We have a router setup as a PSTN router and an IP phone configured as a PSTN phone and 800 and 888 calls come from that phone.
Our HQ is using a MGCP gateway and Branch is using SIP trunk.
I configured dial peer with the destination pattern pointing to CTI ports DNs using G711ulaw codec. I turned on the debug voice ccapi inout but it doesn;t show any output when I place the 888 call from PSTN.
04-29-2014 11:33 PM
Hi.
Which region and which codec is the PSTN router negotiating with CUCM?
Do you hear a fast busy tone on pstn phone when calling the application pilot?
On PSTN router:
conf t
logging buffered 4096
logging monitor debug
debug voip ccapi inout
term mon
and during a call from a pstn phone you should see the output of debug command.
Please post it here.
Carlo
