UCM Dynamic call routing
prupnik
Level 4
Level 4
Is there any solution that Gateway automatically stores information about outgoing calls. If somebody calls back, he is automatically routed to the extension that the previous call was made from.
Like GSM GW http://www.2n.cz/popup/vbl.html?
I have UCM and MGCP controlled ISDN GW.
Best regards,
Patricij
bwilmoth
Level 5
Level 5
Are you looking ofr a feautre called PLAR?
