Unity 7 migration to Connection
jeff.singh_2
Level 3
Level 3
                   we are migrating Unity 7.0x VMO  to unity connection 8.x . so we will be using COBRAS.
we at the same time want to ldap synch the Unity connection  - is this done during the cobras import ?
Also some of the alias's on the unity do not match the AD user - most do but some dont, should we rectify this before migration or can we do it at the same time as migrating ...thanks..Jeff
lindborg
So - couple things.
COBRAS includes a tool called "backup editor" that's designed to help change the alias and/or extension numbers for users in the backup database itself to help when migrating between systes that have some changed alias naming conventions (this is a common scenario I call "while we're migrating, lets fix everything all at once").
The typical process here is:
1. get a backup of the old system
2. Install your Connection server and import your users (in this case you're LDAP users from AD).
3. edit a copy of your backup database (please make a backup copy first) so the aliases match the users from AD
4. Import your users from COBRAS over existing users in your Connection.
Doing it this way ensures you got all the aliases and extensions correct - in other words on the COBRAS user conflict page ALL users should be set to overwrite existing users in Connection - if any of them show "Create new" you know you screwed something up and you can adjust and try again.
lindborg
So - couple things.
Thank you.
Hi Jeff Lindborg ( and all),
went through this procedure as you explained and all went well,
imported users from ldap to connection, exported cobras from unity, made the changes to the cobras data using the editor, and imported to connection using overwrite option. All went ok, the only thing that failed was that my pins did not migrate from unity.
any advise where it may have gone wrong ?
