Unity 8.0.3 Failover Configuration
sbeauton
Customer is curerntly running Unity 8.0.3 Voicemail only, running Exchange 2003.   They want failover added to the current enviroment.   I've been following the install guide found here http://www.cisco.com/en/US/docs/voice_ip_comm/unity/8x/installation/guide/umfo/8xcuigumfox.html  No where does it say to configure failover once your done setting up Unity.   In previous verions you would have to setup failover between both servers but I'm not seeing anything that supports that. (http://www.cisco.com/en/US/docs/voice_ip_comm/unity/403/failover/guide/ex/FG_010.html
  Can someone please confirm if this still needs to be setup in Unity 8.  Thanks
sbeauton
Talked with TAC and they did confirm that you need to run failover like in previous verisons.   Hope this helps.
