Unity administrative COS accidently changed - big problems !
hindsc
I'm very stupid !
During a moment of madness I managed to edit the Unity Default administrator COS, when I actually meant to copy it and create a new COS template. This has resulted in me being locked out of most administrative functions I need to do.
I have been looking around the tools available which may help and I used Data Link Explorer to look at my Unity database. I found a table called Cos, which shows the settings and permissions for both the default administrator and default subscriber. I think that my default administrator is missing the ticks it needs in many of the function columns.
Would it be possible for somebody to send me a copy of their Cos setting or compare mine to theirs so I can see what ought to be in place for a standard administrator template.(Data Link Explorer allows you export a specific table to CSV). I have attached a copy of my Cos table settings.
Once I know where I stand, I?m hoping to enlist the help of one of our DBA?s to help me edit the Unity database and reinstate the missing functions.
Does this sound sensible ? Is there anything else I need to consider ?
This is my only hope before I have to embark on a re-installation. Any help or advice would be very much appreciated !
Thanks in advance,
Chris
My server is Windows 2000, Unity 4.0.5, Exchange 2000
lindborg
Zoinks!
You can basically just turn on all a few of the "access" flags via a DB query and do the rest via the admin - I'm looking at a 4.2 system but I believe these are all the same in 4.0(5) as well - here's the short list I'd set to "1":
AccessCosCUD
CosModifyAccess
WebAdministrator
I believe with those set you can get into the SA and update the COS from with the SA for anything else you may have changed. You can do this in the Query Builder in CUDLE reasonably easily:
UPDATE COS
SET WebAdministrator='1'
WHERE Alias='defaultadministrator'
lather, rinse, repeat for each setting - I'm pretty sure those three will get you in...
lindborg
Zoinks!
AccessCosCUD
CosModifyAccess
WebAdministrator
UPDATE COS
