10-12-2009 09:36 AM - edited 03-18-2019 11:49 PM
I have currently migrated from exchange 2003 to exchange 2007. I worked thru the reconfiguring unity document. I dont end up have a .ps1 file after running the reconfigure message store portion. Everything seems to be working ok. Do i need this file and if i do since its not automatically generating how do i create it manually?
10-12-2009 01:20 PM
It should dump it on your desktop. Did you do this at the console? Because if you did this through RDP, it probably will not work
10-13-2009 07:11 AM
It was done from the console.
