06-19-2008 11:56 AM - edited 03-18-2019 09:09 PM
I am trying to do the following:
Call comes in on PRI with telco sending the digits of 8830
Based on the following schedules the call should get transferred:
Mon-Fri 8am - 6pm
Transfer to 3830
Mon-Fri 6pm - 9pm
Transfer to 4830
Mon-Thur 9pm- 8am, Friday 9pm - Monday 8am, Holidays Transfer to 8840
I need help implementing this in Unity with call routing and call handlers. How can this be accomplished?
Thanks in advance
06-19-2008 12:19 PM
create a schedule for each time frame and then create the necessary call routing rules assigning each one the right schedule
javalenc
if this helps, please rate
06-19-2008 12:44 PM
I set the schedule in the call routing rules, but they have no affect and the only rule that matches is the rule with the schedule of always.
Very frustrating
06-19-2008 12:59 PM
have you considered TOD on the CUCM side?
javalenc
06-20-2008 06:39 AM
I did consider, but the lack of holidays prevents me from using that.
06-21-2008 05:07 PM
Hi Javalenc. Can you give us step by step config for this schedule issue. It will be greateful to you if u give us step since i am littel new to this.
regards
Gem
