Unity connect to 2 clusters
p21
I have 2 Callmanager Clusters and I want to use the Unity server to connect to both. In the integration section I have set up a connection to the first Callmanager fine but when I select new integration I only have the SIP option and the Callmanager option is grayed out and I connot selecy it.
Is this a licence thing where I can only have one integration with my licence, or am I doing something wrong?
Ronan
lindborg
You don't do this by using the dual integration option in Unity - that's for connecting to two different switches (i.e. a CM and a PBX) not for connecting to multiple CMs.
Check out this white paper on how to connect to multiple CM clusters with one Unity server:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_unity/whitpapr/clust_31.htm
