Unity Connection 10.5 and Cisco CER 10.5 High availability license
experts,
Do we need to buy High Availability license for Unity Connection 10.5  and Cisco Emergency Responder  CER 10.5  ?
or just deploy HA and no need license ?
K
Manish Gogna
Hi Karen,
For Unity Connection no such license is needed , the licenses required on Unity Connection 10.x are the following
License Parameter
Feature
Description
CUC_BasicMessaging
Total number of voicemail users
Specifies the maximum number of voice mail users configured in Unity Connection
CUC_SpeechView
Total number of speech view standard users
Specifies the maximum number of Speech view Standard users configured in Unity Connection
CUC_SpeechViewPro
Total number of speech view professional users
Specifies the maximum number of Speech view Professional users configured in Unity Connection
CUC_SpeechConnectPort
Total number of speech connect ports
Specifies the maximum number of Speech Connect calls configured in Unity Connection
CUC_EnhancedMessaging
Total number of enhanced messaging users
Specifies the maximum number of Unity Connection SRSV users configured on Unity Connection. The Unity Connection SRSV users are reflected under this tag only when the branch is active.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/administration/guide/10xcucsagx/10xcucsag310.html
"In a Unity Connection (high availability) environment, only the publisher server needs to be configured and connected with the ELM to obtain the license status and for the license enforcement."
With CER as well the same logic should apply but i didn't get a supporting doc.
Manish
Manish Gogna
Hi Karen,
License Parameter
Feature
Description
CUC_BasicMessaging
CUC_SpeechView
CUC_SpeechViewPro
Manish
Deepak Rawat
Adding to Manish, a separate server license is required for each server. Refer below:
Server Licenses:
Order server software to obtain server licenses for each server, primary and secondary, in an Emergency Responder group. You can order two copies of server software together to obtain a single server license for the server group with a node count of two. You can add a secondary server to an existing Emergency Responder group by ordering an additional copy of Emergency Responder software separately.
You cannot share a server license between the Publisher server and the Subscriber server. You must order a separate copy of the Emergency Responder software to add a secondary server to an existing Emergency Responder group.
Reference:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cer/9_0/english/administration/guide/CER0_BK_CBC9B8B3_00_cisco-emergency-responder-admin-guide/CER0_BK_CBC9B8B3_00_cisco-emergency-responder-admin-guide_chapter_01.html#CER0_TP_L7644ABE_00
Deepak
