Unity Connection 11, Notification, no Caller Name
r.rung
Hello Support Team,
i have updated my Lab Environment to Unity Connection 11.   (11.0.1.21900-11)
The New Missed Call Email Notification is really a great feature.
but can i configure that the Caller Name is sent within the Email?
it works only if the caller has a Mailbox withing Unity connection, but if the caller has no Mailbox, his Name is always send as " from unknown" in the email.
in the Remote Port Status Monitoring Tool i can see that cuc is receiving the Caller Name from CUCM.
Rob Huffman
Hi there,
I would have a look at this bug;
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuz80965
Not getting Caller Name for Outside caller in "Missed call" notification
CSCuz80965
6 Replies 6
Manish Gogna
As per the CUCC admin guide the caller name should be displayed if it is being received by Unity Connection, please check the following
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/11x/administration/guide/11xcucsagx/11xcucsag140.html#pgfId-1170249
If the settings are verified and the issue is still there then i would recommend opening a TAC case.
Manish
- Do rate helpful posts -
Hello Manish,
thank you for your answer.
it really looks like a bug, because if the same caller leaves a message then the synchronized message has the correct Caller Name. but if the caller does not leave a message then the missed call notification has an Caller name of "Unknown".
unfortunately the behavior is the same on Unity Connection 11.5(1).
in the notification email i get the correct name only if the User has a Unity Connection Mailbox.
so for a caller that do not leave a message: i get a Missed Call Notification Email from Unity Connection without the Caller Name
if the same caller leaves a Message and it get's synced to my exchange i can see the Caller Name.
so it seems to be intended to be that way, but i don't think that this is a good design to take the name only from Unity Connection Users because i don't have so much license to put in all my external Contacts as users...
The Bug is solved with CUC 11.5.1.11900-26
Rob Huffman
Hi there,
CSCuz80965
great, thanks!
