Hi All,
Unity Connection 7.0 eth0 Reporting Half duplex to Syslog
Need a little help.
I have a Dev Lab Running Unity connection 7 on VMware ESXI.
The Install is fine and everytjing woks as expected, however I keep getting the following report on syslog the eth0 is set to halfduplex.
I have believe I have changed the Port settings on the Switch interface and on the Unity connection CLI.
But this does not make a blind bit of difference.
Can anyone assist.
Charles
