12-17-2011 02:57 AM - edited 03-19-2019 04:07 AM
Hi Guys,
I am trying to install a brand new unity box, first in the cluster, but I am getting the following error each time:
The installation has encountered a unrecoverable internal error. For further assistance report the following information to your support provider.
Execution of script "/usr/local/bin/base_scripts/sd_ifconfig -eth0 -ethtool "autoneg on" >/common/log/install/capture.txt 2>&1" failed with return-code 256
The system will now halt.
Has anyone seen this error before?
Be great to get some advice.
Cheers
12-17-2011 10:32 AM
Hi Tony,
All of the SR's that come back with this type of error were either due to a bad motherboard and/or NIC on the motherboard, also if the BIOS didn't recognize the NIC or that it had a MAC address. This is something specifically related to the hardware/BIOS settings most likely. You mentiond it's going to be a cluster, have you tried installing the software on the other piece of hardware? That may be worth a shot.
Hope that helps,
Brad
10-22-2014 10:34 AM
I have the same error while trying to install a CUCM 8.6.1.10000-43 on a Cisco UCS server.
Is there any way to continue the installation on this server?
What I will try to install the CUCM on the Subscriber hardware.
BR
Michael
01-30-2015 12:43 AM
Is this resolved. I am facing the same issue when i try to install unity connection SUB.
02-02-2015 02:44 AM
yes this is resolved. It was due to a wrong network adapter in the OVA template.
As we planned after installing CUUC v. 8.6 to upgrade to 10.x we already used the OVA template for CUUC 10.x but there is another network card adapter as in the OVA template for 8.x.
I removed the network adapter and used the network adapter from OVA template 8.x.
BR
Michael
