Unity Connection 8.5.1ES16.11900-16 Call Handler bug
george brown
Hi, I've just installed Connection 8.5.1ES16.11900-16  My problem is with
my call handlers.  If I create a new handler, then edit the closed greeting, I can then enable it, and record my prompt ect - all ok.
If however, I check the "During Greeting / Ignore Caller Input" check box and hit save, the "Status" and "Callers Hear" radio buttons blank out, also the "Play/Record" section greys out
I then cannot go back and remove the "During Greeting / Ignore Caller Input" check box, because when I hit save, I get a blank screen with "Internal Error, try again"
Rob Huffman
Hi George,
It almost sounds like you are hitting this bug;
CSCtn75890 Bug Details Bug #9 of 13 | < Previous | Next >
UC 8.5(1) - Play/Record button grayed out on greetings page.
Symptom:
Cisco Unity Connection Administration (CUCA): The "Play/Record" button under recordings is disabled (grayed out), and the selection under "Callers Hear" becomes unchecked.
Conditions:
When using Microsoft Internet Explorer to administer Cisco Unity Conneciton 8.5(1), and enabling the "Ignore Caller Input" during greeting option.
Workaround:
Use Mozilla Firefox browser to access the CUCA
StatusStatus
Fixed
Severity Severity
3 - moderate
Last Modified Last Modified
In Last 3 Days
Product Product
Technology Technology
1st Found-In 1st Found-in
8.5(1)
Fixed-In Fixed-in
8.6(0.98000.22)
8.6(0.98000.24)
8.6(0.60)
8.5(1)ES29
8.5(1.12012.1)
8.6(0.62)
8.6(0.98000.63)
8.6(0.98000.69)
8.5(1.12013.1)
8.6(1.96000.4)
8.6(0.99981.2)
Cheers!
Rob
Rob Huffman
Hi George,
Symptom:
Conditions:
Workaround:
StatusStatus
Fixed
Severity Severity
3 - moderate
In Last 3 Days
Product Product
8.5(1)
Fixed-In Fixed-in
8.6(0.98000.22)
8.6(0.98000.24)
8.6(0.60)
8.5(1)ES29
8.5(1.12012.1)
8.6(0.62)
8.6(0.98000.63)
8.6(0.98000.69)
8.5(1.12013.1)
8.6(1.96000.4)
8.6(0.99981.2)
Cheers!
Rob
george brown
Thanks Rob!!
That was exactly the issue.
gmb
Rob Huffman
Hey George,
You are always welcome
Cheers!
Rob
