Everybody uses the same page (CUC admin), what you see and can do, depends on the roles you have assigned.
On AD questions, yes, assuming you're an user and that CUC is LDAP configured for sync and authentication, you can also grant you roles.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
