Unity Connection Upgrade Error from 8.6.2.20000-2 to 8.6.2.22900-9
After 2 hours my Unity show me this folow error. Anybody see this error?
06_load-database|Depending on the server specifications and on the level of activity on the system, this may take up to an hour.|<LVL::Info>
Chris Deren
I would stay patient as this seems to be just a progress message.
Chris
And that's not an error, if you look closely at the end, it says INFO
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
