04-04-2012 04:35 PM - edited 03-19-2019 04:42 AM
Hi All,
I have unity connection 8.6 trying to integrate it with CUCM 8.6.2, both are on Demo license at the moment, as I want to test everything before importing the licensess.
I can see the Voice port status as "Rejected" on CUCM, also when I test port on Unity, there is a error saying something like " Verify the Voiceport configuration is exactly the same as CUCM". I checked everything and all is same. I have done too many integration from previous Version and all went very well. But this one is making me too many problems:).
Anyone has an idea?
Hamed
04-04-2012 04:47 PM
Hi Hamed,
How many voicemail ports have you configured on the CUCM and on Unity Connection?
What is the devicename of the VM ports on the CUCM?
What is the devicename prefix selected in Unity Connection?
Have you tried resetting the port group on the Unity Connection and also the VM ports on CUCM?
04-04-2012 06:30 PM
Hi Saurabh/Java,
As I am using the demo license , I just add 1 port. Evrything is same and configured correctly, please have a look at the attachments.
04-04-2012 05:36 PM
that error sounds like there's a mismatch between the names of the VM ports on CUCM and CUC, that's the first thing I'd check.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
04-04-2012 06:48 PM
Hi Java,
Please havea look at the attachments.all same.
thanks you,
04-04-2012 08:33 PM
It may be worth checking to see if the CCM service is started on the CUCM server. If so, restart to see if you can establish the connection.
Hailey
Please rate helpful posts!
04-04-2012 09:45 PM
Hi David,
I did restart both Unity and CUCM and it did not work.
04-04-2012 10:00 PM
Have you added CUC as application server in Cisco CUCM. Also have you given proper AXL parameter under
Phone System and CUCM Server configuration under port group.
Ronak Patel
