Unity Connection 8.6 Web interface for email?
Mark Verwey
Is there a way to look at your voicemail via a web interface?
Jaime Valencia
There are plenty of options
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/8x/requirements/8xcucsysreqs.html#pgfId-365485
java
if this helps, please rate
I figured that part out already because when I installed it I had the COS setup that way.  The missing link for me is the web address.
https://x.x.x.x/ciscopca
java
Apart from what Jamie mentioned, you can also use https://x.x.x.x/inbox
