Unity Connection 8 running out of disk space
sahong
I get the following error and I was wonder what files I could delete to make room on my server?
TIA,
Sam
Command Line Interface is starting up, please wait ...
log4j:ERROR Failed to flush writer,
java.io.IOException: No space left on device
        at java.io.FileOutputStream.writeBytes(Native Method)
        at java.io.FileOutputStream.write(FileOutputStream.java:260)
        at sun.nio.cs.StreamEncoder.writeBytes(StreamEncoder.java:202)
        at sun.nio.cs.StreamEncoder.implFlushBuffer(StreamEncoder.java:272)
        at sun.nio.cs.StreamEncoder.implFlush(StreamEncoder.java:276)
        at sun.nio.cs.StreamEncoder.flush(StreamEncoder.java:122)
        at java.io.OutputStreamWriter.flush(OutputStreamWriter.java:212)
        at org.apache.log4j.helpers.QuietWriter.flush(QuietWriter.java:49)
        at org.apache.log4j.WriterAppender.subAppend(WriterAppender.java:306)
        at org.apache.log4j.RollingFileAppender.subAppend(RollingFileAppender.java:225)
        at org.apache.log4j.WriterAppender.append(WriterAppender.java:150)
        at com.cisco.iptplatform.fappend.ciscoRollingFileAppender.append(ciscoRollingFileAppender.java:81)
        at org.apache.log4j.AppenderSkeleton.doAppend(AppenderSkeleton.java:221)
        at org.apache.log4j.helpers.AppenderAttachableImpl.appendLoopOnAppenders(AppenderAttachableImpl.java:57)
        at org.apache.log4j.Category.callAppenders(Category.java:187)
        at org.apache.log4j.Category.forcedLog(Category.java:372)
        at org.apache.log4j.Category.info(Category.java:674)
        at sdMain.main(sdMain.java:648)
   Welcome to the Platform Command Line Interface
VMware Installation:
        7 vCPU:  Intel(R) Xeon(R) CPU E7- 4870  @ 2.40GHz
        Disk 1: 160GB
        8192 Mbytes RAM
    WARNING:
        The common partition on the disk is almost full.
        Please use the "file delete" command to remove old log files.
        Otherwise, some CLI commands will not function.
        Please login in again after deleting the log files.
        If this message persists, then please check the file system using the Recovery Disk.
sahong
All,
A little more info, the offender seems to be:
admin:show diskusage activelog
This command can take significantly long time,
and can also effect the system wide IOWAIT on your system.
Continue (y/n)?y
Filesystem            Size  Used Avail Use% Mounted on
/dev/sda6              99G   94G     0 100% /common
74G     /var/log/active/tomcat/logs/catalina.out
Does anyone know if it is safe to stop tomcat, delete the file and restart tomcat?
