Unity connection Auto Attendant call transfer
kpintens
I was wondering if someone could help me guide where to start troubleshooting on the following:
In auto attendant I have setup a call handler that needs to transfer the call to an extension. The operator says it is transferring but the call does not come through.
I checked the CSS of the voice mail ports and that has the extension partition in, Unity is call forwarding rule is set to match all calls.  In the call handler the transfer rule is set up for transfer to alternate extension.
Any ideas where to look first
Thanks in advance
Koen
16 Replies 16
kpintens
forgot to mention, Unity Connection 8.0.2
Rob Huffman
Hi Koen,
If this extension does not have a configured mailbox on the
system you will need to check the Default System Transfer
restriction table in CUC admin to allow calls to this number
or range of numbers
Cheers!
Rob
kpintens
Hi Rob
Thanks for the answer I had a look the default system transfer
There is one that allows 9??????????*  So do I read this correct, starting nr 9 followed by 10 digits?
I have another forward to an extension (Hunt pilot actually) and that starts with 8 followed by 8 digits and that works ok
Koen
Rob Huffman
Hi Koen,
This rule;
9??????????*
is blocked on our system
But above it in the table is;
6???*
Which allows transfers to the 6xxx range of numbers even if they do not have a mailbox
on Unity Connection.
On the Call handler itself, are you using Caller Input, free dialing or after greeting action
to try and route the calls to the defined DN?
Cheers!
Rob
kpintens
Hi Rob
That is the only system rule enabled, others are blocked, the default transfer ones are all enabled
The call handler has a transfer rule to extension (not unity subscriber)
Tried different settings on the greetings [standard] (ignore caller input etc, different call actions) but no joy.  It does reach it because when I untick the play prompt (wait while transfer) it does not play it.
both DN's are in the same partition (VM ports and destination), I presume this rules out CSS mismatch??
Koen
Rob Huffman
H iKoen,
These are always tricky when first setting them up and wrapping your head around
how this all works together
A quick test for the CSS question is to set up a test phone with the same CSS
as the CUC ports and try calling the required DN.
Are you using release to switch?
Does CUC/Leslie come back with any response when trying to link through
the Call handler to the DN?
Have you tried setting a specific rule above the 9??????????* in the
restriction table like we did?
Cheers!
Rob
PS: just to clarify, the call routes through the AA before coming to the Call Handler?
Hi Rob
It looks like it hits the menu structure in AA, have no greetings there yet but knowing the caller input I get to where I want to go.
At the final Call Handler Leslie states transferring but then 40 seconds later it drops the call (tested this by removing the prompt and then I heard nothing when arriving there)
yes, release to switch is selected
the setup for Default transfer (opposite system transfer) is allow all (nothing blocked)
The weird thing is that there are already AA's on there and they work, one has the extension being a subscriber on Unity Conn. but the other one isn't
Not sure if this is related but for this site on the Callmanager the hunt pilot is not working either.  This could influence the actual call handler destination but for testing puproses that call handler is now set to transfer to my extension
Koen
Rob Huffman
Hi Koen,
I've mocked this up to test our theories out here
New final DN is 6777 which has no mailbox on Unity Connection
New Call Handler is 6198
On the CH - 6198 - it doesn't show 6777 as the extension in this post but it's there.
Transfer Action
Transfer Calls To:
I first call the main AA for our Campus and key in 6198. This then routes to 6777 as we expect.
This is without any settings on the restriction table for Default System Transfer (I removed 6???*) for
testing. So we have to assume (I know ) that the issue is not related to the settings
on the Call handler or restriction tables that you described as having configured.
Did you try to set up a test phone with the same CSS as the CUC ports and try calling the required DN?
Cheers!
Rob
Hi Rob
I can't test it because I only have one IP phone.  I did use the dial plan analyzer and that stated routepattern (they are all in the same partition and the 2 CSS have that)
I see you don't have wait for x rings, will take that off here
Looking again at a working one without subscriber, well I thought, in the message setting of that call handler there is a message recipient defined.  I tried adding one in there but still the same dead air after the wait while I transfer message....
More info, I unblocked the * in the default system transfer restriction rule and it still doesn't forward the call to the DN
Koen
Rob Huffman
Hi Koen,
Just as an FYI, the number of rings is set to 4, it just didn't paste properly.
I just used the Remote Port Status Monitor Tool to capture a sucessful call with
the flow from our "mock-up" @ Call Handler 6198. Note that the call routes in via 8700 main AA;
06:53:05, New Call, CalledId=8700,  RedirectingId=8700,  Origin=16,  Reason=8,  CallGuid=CBCA9FA5BCE44237BFD5A55E05B03022,  CallerName=Rob Huffman,  LastRedirectingId=8700,  LastRedirectingReason=8,  PortDisplayName=CallManager-1-002,[Origin=Invalid],[Reason=Invalid]
06:53:05, AttemptForward
06:53:05, State - AttemptForward.cde!Dummy
06:53:05, Event is [NULL]
06:53:05, PHTransfer
06:53:05, State - PHTransfer.cde!LoadInfo
06:53:05, Event is [TrueEvent]
06:53:05, PHGreeting
06:53:05, State - PHGreeting.cde!PlayGreeting
06:53:05, Call answered if needed
06:53:05, Playing greeting for Call Handler:  Opening Greeting
06:53:14, DTMF received [6]
06:53:17, DTMF added [198]
06:53:17, Event is [NULL]
06:53:17, PHTransfer
06:53:17, State - PHTransfer.cde!LoadInfo
06:53:17, Answer Phone if needed
06:53:17, Event is [FalseEvent]
06:53:17, State - PHTransfer.cde!CheckPlayTransferIntro
06:53:17, State - PHTransfer.cde!XferCall
06:53:18, Event is [HangupEvent]
06:53:18, State - PHTransfer.cde!DoHangUp
06:53:18, Idle
You can see where CUC has transferred the call right here;
Can you try to capture the same from your set up to see if they match up this way we can see if the call leaves
CUC and you can concentrate on the CUCM side of the house
Cheers!
Rob
Hi Rob
Stupid question, how do I get to those trace output
on the port monitor I can see things
Rob Huffman
Hi Koen,
Not a stupid question at all my friend
These are actually 2 different tools;
This Tool is from the excellent suite of Unity Tools. It seems to be a little
more informative and easy to capture than the info from RTMT;
Port Status Remote Monitor for Connection (rPSM)
http://www.ciscounitytools.com/Applications/CxN/PortStatusMonitorCUC7x/PortStatusMonitorCUC7x.html
Cheers!
Rob
Thanks Rob
Downloaded and will post test results soon
connection refused even when I put my IP-address in the list
Message was edited by: Koen Pintens
Rob Huffman
Hi Koen,
Did you check the listed checkbox as well as setting the IP address of your machine?
For Connection 7.0(1) and later you need to two do things in the “Conversation” section in the Advanced Settings in the administration interface before the rPSM will work properly.
  1. Turn      on the remote port status monitor output.   This is a checkbox titled      “Enable Remote Port Status Monitor Output”
Cheers!
Rob
