Unity Connection Hardware
scooter817
Level 2
Level 2
Hi Everyone
I wanted to know can someone point me in the direction where I can find out if our Unity connection server is upgradable to 8.5 or do I have to stay at 8.0. I want to enable Visual Voicemail for our users and I've had 2 different people tell me different things. One person told me that my MCS 7845-I2 can't be upgraded to 8.5 and I've had another tell me that it can. Visual Voicemail requires that you run atleast 8.5 and I don't want to go down the path of upgrading the servers and they don't support what I'm trying to do. Thanks in advance for the help and have a great day as always.
Jaime Valencia
Cisco Unity Connection 8.x Supported Platforms  List
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/supported_platforms/8xcucspl.html
Above can be found in the Install and upgrade section of CUC documentation, or just by searching CSC, as there are plenty of threads with compatibility tables.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
