Unity Connection 8.6 Message playback order bulk edit
pvezina
I would like to change the message playback order to oldest messages first in Unity Connection 8.6. I know how to change it user by user and how to change the template, but is there any easy way to change the 400+ users that are already imported in bulk? Thanks!
Patrick Vezina
Rob Huffman
Hi Patrick,
Here's a clip;
To Edit User Account Information in Bulk Edit Mode (some editing from original)
Step 1 In Cisco Unity Connection Administration, on the Search Users page, check the applicable user check boxes, and select Bulk Edit.
If the user accounts that you want to edit in bulk do not all appear on  one Search page, check all applicable check boxes on the first page,  then go to the next page and check all applicable check boxes, and so  on, until you have selected all applicable users. Then select Bulk Edit.
Step 2 On the Edit Conversation>Flex Stack page, change settings as applicable.
Note The  Status message at the top of the Edit Conversation page tells you how  many user accounts are being edited. Also note that the page is  populated only with the fields that you are allowed to edit in bulk  mode, and that the fields available for edit also depend on whether all  of the user accounts reside on the local server.
Step 3 If applicable, set the Bulk Edit Task Scheduling Fields to schedule the Bulk Edit operation for a later date and/or time.
Step 4 Select Submit.
Step 5 If  applicable, continue to change settings for these user accounts on the  related pages available from the Edit menu. As you make changes on each  page, select Submit before going on to the next page to make additional changes.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/user_mac/guide/8xcucmac090.html#wp1049545
Try a couple of test users first to come up with the exact plan.
Cheers!
Rob
"Why not help one another on the way" - Bob Marley
Rob Huffman
Hi Patrick,
Here's a clip;
Cheers!
Rob
That was too easy. Thanks a lot!
Patrick Vezina
Rob Huffman
Hi Patrick,
You are most welcome my friend
Cheers!
Rob
