unity connection high cpu ?
baselzind
Level 6
Level 6
i have
2xcucm 10.5.2
2xcuc  10.5.1
2xcup 10.5.2
my unity connection is showing high cpu usage on my solarwind with over 90% usage , the below screenshots from the cli and the cuc os system page show the usage detail but im not sure what can i do to reduce it , i tried several times to shut off and on and to restart it with no use , please help???
Mohammed Khan
Does VM specs match OVA Template.
Whats the underline HW?
Have you noticed any performance issue on VMware ESxi ?
User is consuming most of the CPU.
check the output of "show process using-most cpu" and restart specific service,if not you can reboot specific server.
1-yes it matches
2-
Processor Speed 3300
CPU Type Intel(R) Xeon(R) CPU E5-2643 0 @ 3.30GHz
Memory 4096 Mbytes
3-my cup and cucm running on the same server with no performance issues.
4-i tried that command but i couldnt figure out the output, i attached the output
