Unity Connection LDAP Error
gmgarrian
Level 4
Level 4
I'm trying to setup a Unity Connection server with an LDAP directory and when I save the configuration I get this error message:
Error while Connecting to  ldap://172.16.1.2:389, null
The UCONN server is connecting to a Windows 2000 DC running Exchange 2003.
I think I'm missing something simple but I'm not sure what.
Thoughts?
Bradford Magnani
Sounds like you may either have an incorrect IP address and/or port # for your DC or GC.  Port 389 for a Domain Controller, and if the server is a Global Catalog, you'll need port 3268.  Another possibility is that port 389 may be blocked by some sort of ACL or firewall.  I would try the port change first and re-verify your IP address and if that doesn't get you anywhere, setting up a network capture to see what may be happening during the bind request is your next step.
Hope that helps,
Brad
I actually had the AD path incorrect.  I used an OU when I should have used a CN.
Thanks for the help!
