unity connection license
hello all
i have 2 unity connection servers, version 7.1 members of the same cluster
i need to install the licenses, i have 2 pak numbers with the exact amount of subscribes, vm ports, etc
do i generate one license with the mac of the pub, and one with the mac of the sub ?
please let me know
thank you
2 Accepted Solutions
David Hailey
Cristobal,
You need to generate 2 licenses.  The first is based on the Pub and should be a full license (all fields in it and populated).  The second is based on the MAC of the Sub and should be an HA license.  You may need to work with licensing@cisco.com to make sure this license is created properly.  The Sub will inherit ports, users, etc from the Publisher license.  The HA license for the Sub only contains the ports you purchased for HA, voice rec sessions, etc (port-based info).
Hailey
Please rate helpful posts!
Rob Huffman
Hi Cristobal,
Just to add a touch to Hailey's great info (+5 "H")
We found this doc pretty helpful when we were first trying to
set up our Cluster Licenses
System Administration Guide for Cisco Unity Connection Release 7.x
Managing Licenses
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/administration/guide/7xcucsag310.html
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
David Hailey
Cristobal,
Hailey
Rob Huffman
Hi Cristobal,
Managing Licenses
Cheers!
Rob
thank you very much it helped me a lot
