Unity Connection - Multi Language
Aaron Harrison
Unity Connection 1.2 - I've installed the UK English pack so now my system supports both UK/US english.
I've set the default language for the system to UK, and the users are set to UK.
However, if I go into any TUI bit to record a greeting I'm always prompted whether I wish to record for US or UK English - is it possible to disable US English so that this question isn't asked?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
8 Replies 8
lindborg
No, for each active language on the system (you can take US english out of the active list if you like) subscribers are given the option to record greetings for any of the languages - there's no way to have a list of languages that are installed and active for the TUI that are not offered for greeting recordings for subscribers.
Hi Jeff
OK - so how do I remove a language from the active list?
Thanks!
Aaron
Hi Jeff
Thanks!
Aaron
Anyone????
Ta
Please?
Ping
Ping
waynejackson
I need to add a second language onto an existing unity connection install but can only locate the compelted install files via the download page- is there a language service pack and if so where can I obtain it it
thanks
