Unity Connection Notification
Bernece Johnson
Does anyone know of a way to send a notification to Email (Group Wise) of a voicemail without sending the actual message? Basically I have set it up so that Unity Connection will send an email to my Groupwise email account and it works, but we don't want the attached .wav file. Is there a better way to send a notification of a voicemail then what I am using?
Brad Magnani
Sounds like you may have Accept and Relay feature configured?  You may want to look into SMTP Notifications:
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/administration/guide/7xcucsag200.html#wp1049727
Hope that helps,
Brad
Brad Magnani
Hope that helps,
Brad
Thank you for your response. It was exactly what I was looking for.
