Unity Connection SQL query that displays subscriber and extension
Jay Schulze
Does anyone know a sql query for unity connection which will show just Alias and Extension?
lindborg
if you just want the alias and primary extension of the user you can simply get them both from the vw_subscriber view:
select alias, dtmfaccessid from vw_subscriber
If you need all the possible extensions for users (users can have 10 alternate extensions for instance) you'll need to pull them in from the vw_dtmfaccessid view like this:
select vw_subscriber.alias, vw_dtmfaccessid.dtmfaccessid
from vw_subscriber, vw_dtmfaccessid
where vw_dtmfaccessid.Parent_SubscriberObjectId = vw_subscriber.ObjectId
order by alias
5 Replies 5
lindborg
order by alias
Thank you sir. That works well.
I tried both but didnt work with 'run sql '.
Is there any command to see with calling party
if you're running this at the Unity Connection admin command line you need to prefix "run cuc dbquery unitydirdb " in front of the SQL query there - UnityDirDb is the main directory database for Unity (as opposed to the MbxDbs for messages and such).
Not sure what you're trying to query here with regards to calling party - are you wanting to search for messages in the database from particular calling numbers or the like?
Many thanks
something like this, this is from CUCM. similarly from CUC I am looking for customer number,subscriber and date time
call_type callingpartynumber originalcalledpartynumber datetimestamporigination
S 113122 113118 2019-02-04 09:29:11
S 113122 13146529924 2019-02-04 13:32:43
