Unity - Directory Handler does not find Call Handlers
carly_premo
Does anyone know of a setting in Unity that will allow directory handlers to find call handlers when searching? It appears to me that it only finds subscribers.
To have call handlers "appear" in the names directory do the following:
You can create internet subscribers with a recorded name and extension which show up in the names directory.
Change the transfer type to "play greeting"
If you configure the internet subscriber to play blank greeting and change the after greeting action to "play greeting for call handler" you have then routed the caller to the call handler.
regards,
Scott
lindborg
Directory handlers will only find subscribers (full or remote), there's no way to have it find call handlers by name for outside callers.
That's what I was afraid of. Thanks for responding.
regards,
Scott
Thank you thank you!! That worked, and completely solved my problem!
